As I was reversing and about to change back to D something happened to my gear lever.
The pull button that lets it move went slack, the lever is stuck in the R position and I can't select any gears!
Any ideas other than calling the RAC?
Solved it...
Something inside the gear lever snapped. Found a screw driver and took the lever off. Works now by moving by rod inside manually
I’ve not looked at the gear mech yet, maybe it’s something else that should be cleaned and lubed, I’ve had 2 door cables break from corrosion, so it’s time to start looking around the car
Cleaning and lubing it wouldn't have helped :(
Need a new gear knob!
When you pull the silver lever up it pushes the other end down. That then pushes a rod inside the gear lever down that then allows the whole thing to move.
The bit that snapped off is the bit that presses on the rod
I’ve got a gear knob, not 100% on the bit you need, I’ll have a look, I think it was a black one, not chrome effect
Amazingly I found the button, it’s black, your welcome to it, pm your address if you want and I’ll get in post today
Thanks for the offer but I've already ordered one from eBay.
