So what is your verdict on the wheel bearings? The RH one has gone and the LH is OK?
I changed both of them. The corroded one was the noises right side. Alls good now.
What I was surprised by was the amount of corrosion and grime inside that hub. The other one looked very new.
I’ve tossed away the corroded one and will put the other one on the shelf in case I ever need a good hub. I’m planning on tacking the front two next month.
Price for FTC2249 looks to be outrageous. Twenty drinking vouchers (ish) for a plastic bush!
Tempting to dig out some Delrin and make up a batch when I have some spare time (that'll be never then).
Clive, I didn’t buy those plastic pieces FTC2249. I was able to fit a socket inside the hub attached to a driver and hammer them out with no damage. As mentioned, the hubs I bought cane without them and if they are not fitted on new hubs the aBS sensor will not fit snuggly. Easy enough to remove...
