So I have been trying to nurse my a/c back to health... compressor changed, o rings replaced, full a/c charge, clutch engages off a 9V battery and a/c will run cold, evaporator will go sub 10 degrees no problem. With the regular electrics connected then I can see the a/c request kicking in within a few seconds of ignition start (nanocom, read from the ECM). I can also toggle the a/c request on and off with the a/c switch, so the nano reading is good, and live. Request is an active-low 12v connection.
The A/c grant is 5V, also active low. As far as I can see I don't get the grant back from the ECM - does anyone have the exact GEMS criteria for grant? BBS talks about temperature, load and acceleration... but what specifically? The nanocom HEVAC connection is pretty unreliable once the car has started (it says it can't connect, but still reports most input variables), but it reports no grant. When I have time I will pull the ECU and confirm that by testing the pin. I tend to believe the nano for now re lack of grant, but not 100%. Because the grant is active low then there can't be a wire break
As a plan B I was thinking to join the A/c request output from the HEVAC, via a 5V regulator to the a/c grant input to the HEVAC - then they would both go active low together automatically, and would be 12v/5v inactive....would this do as a work-around?
Thoughts welcome
Rgds, Rob
I always start the engine first before trying to connect to the HEVAC and it will often come up with a can't connect error but if I back out of it and try again it almost always connects the second time. You should be getting 12V out of the HEVAC when it tries to engage the compressor clutch but it is 12V and not full battery voltage so I suspect there is a regulator in there (or the volt drop through whatever is doing the switching drops it a touch). Check at the multiway behind the RH kick panel and see if you are getting a voltage there. Also have a look at the readings from the sensors, someone on .net found that he had an open circuit evaporator temp sensor which meant the HEVAC wasn't trying to engage the compressor as it thought the evaporator was cold enough already.
Tnx Richard, I have the a/c request, so there shdn't be a sensor problem with HEVAC... But that's why I'm asking about the ECM conditions - although what's on nano looks normal enough - for some reason the ECM isn't returning the a/c grant, so if I knew the exact conditions I could make sure they're all reading ok and move on through the diagnosis.
Everything i've tested seems ok, but the only odd thing is I see 11 something volts at the compressor plug even before the ignition comes on...but it's only 0.1 or 0.2Amps so not strong enough to pull the clutch in. That wd only have come from 2 sources, i think: i. the Fuse box to the dual pressure switch, or ii. HEVAC to dual pressure switch. Maybe the pressure switch is playing up.
I'll test all the pins on C102/202 next, didn't get time today before the rain started....
romanrob there's a technical service bulletin for this case, IIrc ... which I now realize have posted as a link before eyesroll
That TSB updates the system to that used on the Thor where instead of the HEVAC driving the clutch directly, it powers a relay which switches battery voltage to the clutch. It needs the big resistor as the early HEVAC will detect if insufficient current is being drawn (the amount needed by the relay compared with the amount needed by the clutch) so will assume the pressure switch is open due to a lack of refrigerant and not try to operate the clutch again.
Yes ... but it mentions as well the second positive lead to rise the amount of ampere current for the compressor clutch or the whole system ;-)
But I might be on the completely wrong track for romanrobs problem ...
Thanks KCR you reminded me that I had one of these harnesses in the garage, so i fitted it last night. After a few ignition cycles without the clutch working then it just randomly engaged - once, and got the evaporator down to 5 degrees - but i can't replicate that... I will do a bit more digging, I smell the end game
So in the end I gave up - there is some condition not satisfied at the ECM, and I've no idea what... so in the RH footwell i earthed the grant line going back to the HEVAC. The clutch still goes on and off with the a/c button for sure - i just need to check that over-riding the Grant feature has not also bypassed the temperature check that the HEVAC ECU makes on the evaporator
I have tagged onto this posting as I have a very similar problem to romanrob post 7.
I fitted the loom as in TB 0010 from my now spares 1998 model.
I knew there wasn’t a full charge of gas in the system from attempts to get working a/c a couple of months ago, before the loom was fitted so I just put a jumper lead across
Trinary switch socket 1 black/yellow and 2 white/light green.
I had seen in the post 9 that it was on the 3rd starting the compressor clutch engaged … well so did mine, so downed tools for the day.
The next morning started engine …. No clutch engagement.
I thought it might be because not enough gas on the system so booked it in at my auto electrician.
He evacuated the system and fitted the new receiver drier and pressure switch 2 single switch that I supplied and re gassed it. Only to tell me the compressor clutch was not engaging so I had an electrical fault.
I have been trying to get my old fashioned brain to sort it out.
If I jumper across relay 10 socket 30 and 87 the clutch pulls in and cold (not freezing) air starts to come out of the dashboard vents. But there is no power at 86 to pull the relay contacts in.
Very late Friday afternoon I noticed a sticker in the engine area saying 700 grams was put in the system. Just looking at info on the net last night I realized that is not a full charge, the manual advised me it should be 1250 gms.
Is there a chance that with a full charge of gas the feed to relay 10 would be there to pull the compressor clutch in ?? My electrician does’t work weekends)
Nanocom lists the only fault is 6 RH blend motor current fault.
It also says YES to the grant.
Again any ideas would be most appreciated
Andrew
Yes to the grant means that the HEVAC is trying to engage the clutch but with only 700 grams of R134a in there, the pressure switch will be open circuit so the clutch won't engage. It really does need a full charge, that is why you have nothing at pin 86 and when you force it in with the jumper you are only getting coldish air from the vents.
While on the subject of AC, I filled a diesel P38 yesterday which only takes 1100 grams. The owner has had the car for almost 10 years and never had working AC but was complaining that his kids weren't happy being driven around in a mobile greenhouse over the summer. I pressure tested it for him and the condenser was leaking. He replaced that and I put 10 bar of Nitrogen into it and unplugged the compressor so it didn't try and engage. 3 weeks later it still had 10 bar of Nitrogen, so we declared it good. With a full charge of refrigerant, the Nano reported an evaporator temperature of 4-6 C but air from the vents was reading around 10C. Another good reason for fixing the leaks in the ducting..... But of course now he has another problem, condensate pouring into the passenger footwell.
Regarding the AC Request & Grant, remember these go via the large connector under the coolant header tank. Could just the a bad connection there, but worth checking the voltage at the engine ECU end as well as at the HEVAC ?
The compressor clutch TSB is a completely separate issue.
The first time mine decided it wasn't going to pull the clutch in, I measured the voltage at the compressor and found around 7V. This would only come on briefly as insufficient current was being drawn so the HEVAC disconnects the feed and doesn't try to engage it again. I cobbled together a few bits of wire and a relay to supply a full 12V to the compressor but that didn't work as the relay didn't draw sufficient current so I had the same problem, hence the reason why the TSB adds the resistor to increase the currant draw. My problem turned out to be corrosion in the 18 way connector behind the RH kick panel, 12V in but only 7V out. At that time, I simply put a link wire in place of the connector but cut it out and replaced the whole connector later. I've had no further problems and haven't seen the need to do the mod in the TSB. With the kickpanel connector cut out and a squirt of contact cleaner in the one under the reservoir and at the pressure switch, there's never been a problem. The same goes for the red 4.0SE I bought last year, checked the kickpanel connector for corrosion and gave all connectors a squirt of contact cleaner and it just works.
The other thing that can cause intermittent operation of the clutch, is the air gap on the clutch being too wide. If this is the case what usually happens it will operate fine when ambient is low but fails to kick in when it gets hotter (just when you need it). The air gap on mine was over 40 thou and it worked fine until the ambient got up to 23C, just when you start to need it. Spec says it should be between 16 and 31 thou but the smaller the better. It can be adjusted by taking a spacer out from behind the clutch front.
Thank you Pete12345 and Gilbertd for the comments.
I found the connector you said about while I have been trying to understand the wiring diagrams and due to their location I checked them. They looked clean but sprayed them with contact cleaner.
Sprayed contact cleaner on every plug and socket I could find.
Having seen various people having problems with the 18 way connector under RH kick panel I have solder jointed all the wires. Sorry I forgot to mention that.
I will also do the same with the connector under the LH panel soon.
Yes I spotted the compressor clutch gap that a is mentioned a lot and adjusted the clearance, that is remover the shims and got a gap of to 0.35 mm.
( 0.35 to 0.65mm is listed as the accepted range ) Forgot to mention that as well Sorry.
A couple of months ago I booked it in with my very helpful auto elec chap he gassed it up and declared that there was an electrical problem that I would have to find as the compressor clutch was not pulling in.
Hence the fitting of the TBS kit from my parts car. That's when I got the similar funny behavior that romanrob said in post 7 .
Confident that my problem would be fixed I got from the UK a new receiver drier and pressure switch 2 (the single one) and changed the trinary switch 1 from the parts car, It was working only 6 months ago, and booked into my auto elec chap.
He gassed it up and declared that the problem was still there ! ! !
Thus my post 9 above.
After Gilbertd's post 10 I am now more informed about gas requirements. My auto elec chap has written on the sticker on the car "gas 700gms"
Why didn't I look in the manual ? ? It clearly states 1250 gms.
So I will be phoning on Monday for an appointment to get the air con gassed ! ! ! ! But will that fix the non working air con ? ? As the saying goes watch this space.
Hello All
Sorry for the long post I just don't seem to be able to shorten down the problems explanation.
I managed to get my auto elec to put 1200 gms in the air con system, the pressures, according to him, were high, so the last 50 gms is still in their machine. Persuaded him to have the motor running but nothing got the compressor clutch to pull in. He pulled out the relay 10 and put a jump lead across 30 / 87 so the clutch pulled in to complete the refill.
Once that was done and relay replaced, (clutch dropped out) I noticed the HEVAC screen had on left a snow flake then EXT – 40c. He agreed that the ambient sensor could now be the problem. Nanocom reckoned it had changed its mind now NO grant.
Today I took the ambient sensor off the 1998 spares car (air con was working 6 months ago) easy to remove from in front of condenser. Managed to get socket off the in the air duct sensor and plugged the replacement into it and left it hanging in the left foot well, probably not the most ideal place.
Running on a fast idle nothing to start with HEVAC on low/low showing snow flake EXT -40c. then snow flake stayed on the whole time but NO EXT -40c and a/c grant YES system started blowing cold air from dash vents.
With a day time temp of 30 deg c.
It took nearly 30 minutes to see on the Nanocom
Ambient temp 11c it stayed at 11c the whole time
Aspirator temp 24c it started on 26c
Evaporator temp 5c it started on 18c at 5c the clutch was operating in / out at times (as it should I believe)
Heater core stayed at 80c after warming up.
Dash centre vent temp 4c.
Then clutch dropped out and EXT-40 joined the still visible snow flake and warm air again. The snow flake is obviously a problem as it is only to show possibility of road ice.
I switched off motor and left it for another time.
The ambient sensor, mounted in front of condenser, must have been working in the other car as the air con was operational.
Maybe if I removed it from the wheel well, mounted it out the front and ran two wires back to the socket in the cabin?
I can’t see that would upset the HEVAC.
Looking at RAVE diagram for 1997 there is UO wire out of HEVAC to sensor and WB wire back no connectors. Sensor in air vent. Wires not shown in 12 pin plug LH side.
1999 diagram shows same colour wires going via 14 pin connector in behind LH wheel well panel. Sensor is out the front of car.
It appears that the sensor is no longer available. So has anybody found a usable replacement? Is my problem the sensor or something else as well?
I made up my own loom for my 1954 Citroen, made up loom from fire wall to lights for my 1974 Citroen Dyane, worked on my 1998 Defender, but the electrics of my P38 are in another world.
Thank you
Andrew
The ambient sensor values are in the RAVE description. Any NTC sensor with similar characteristics should work.
RAVE HEVAC Description
Note: I have found that after the HEVAC loses the sensor connection & goes to -40degC, you need to clear faults & power cycle the HEVAC for it ambient to work again.
Hello All
My air con problems I hope are fixed.
Hevac recording -40 deg and snow flake symbol from faulty ambient temperature sensor and heater pipe sensor recording silly temperatures according to my infra red temperature gun. Both these fixed using thermistors as in this post https://lr4x4.com/topic/109433-p38-hevac-sensors-replacementmodification/
Living outside of a major city purchasing parts and then mounting them has taken a bit of time. I used this to mount them…
https://mgchemicals.com/products/adhesives/thermally-conductive-adhesives/high-thermal-conductivity-adhesive/ 8329TCS – Thermal Adhesive.
I found the a/c grant was actually varying “Yes / NO” and after checking connections mentioned in this set of above posts the problem was at the Hevac. Connector C246 on right side of Hevac has, on my car, very little free play in the wiring loom over the years of this unit being taken out and moved about it had put strain on this connector. It carries the wires for the grant. The only solution I came up with at the moment was to install the connector with a thin piece of plastic card so that it was a tight fit.
As stated earlier, TBS wiring loom was fitted and compressor clutch gap had been adjusted to the lowest specification. The connector in the right side foot well had been removed and wires soldered. The correct amount of gas was finally in the system. And still no air con unless the relay 10 terminals 30 / 87 were bridged. The earth 85 was good. There was still no 12 volt to relay 10 86 pin.
At connector C244 on the Hevac the black and yellow wire on pin 7 was dead. This wire is to relay 10 pin 86. Other power wires into the unit were okay.
I took relay 10 out of the fuse box made up wires from pins 30, 87 and 85 back into the fuse box. Then for now, took a 12v feed from the accessory plug/socket inside the car through a fuse and on/off switch ran it through the firewall to relay 10 pin 86.
12v to pin 86, engine on, cold air virtually straight away. Nanocom readings all correct. A couple of 45 minute test runs static in the carport have shown operation of slow condenser fan followed by fast fans, evaporator temp going down low and compressor cutting out and back in on the rise of the temp.
I went to go for a run and realized I have another problem ….. but not air con so that will be in a new post trying to seek help with that !!!!!!
Andrew
You need a replacement HEVAC. The fans should run at low speed when the compressor clutch is in and only go to high speed when the pressure in the AC system gets too high. The power to the relay from the Black/Yellow wire on pin 7 should only be there when AC Grant is showing Yes. That is what controls the clutch to stop the system being over-pressurised. With it having a permanent 12V on it, that feature has been removed.
That link is useful. My heater pipe sensor died, or it would read correct when cold or hot, but while heating up it would go to -40C. I found they are NLA but from a post on rr.net, that said it needed a 22k thermistor, I did the same as described in that link. Only to find that it read very low. Added a 10k resistor in parallel and it reads something like sensible so the heater works as it should but not correct. That link shows a 10k thermistor being used so it looks like I'll be changing mine.
Thanks Gilbertd
I have been trying to fathom out the operation of the ac system and do not put myself forward as an expert on the matter my only real source is the manual and info from Marty.
Am I seeing it wrongly.
The pin 7 should be activated by the yes/no grant and that is not happening so hence my "external" 12v source the the relay 10. So yes I think the Hevac is faulty.
However doesn't that signal only activate relay 10 that then sends the power down to the trinary switch that with the the gas pressure activates the clutch.
Then isn't it the two pressure switches that govern the fan operation I quote a post from marty who in turn is quoting figures from the manual.
https://www.rangerovers.net/threads/ac-update.52810/
marty_nz
Dual pressure switch (trinary sensor) under 17psi or over 435psi, and the switch will be open circuit
Between 35psi and 305psi, the switch will be closed circuit (A/C compressor will kick in)
AJ comment So ”open circuit” means it will cut the power to the clutch thus saving compressor damage.
The single pressure switch is the one that turns the fans on/off to start with:
Under 189psi, the switch will be open circuit
Over 247psi, the switch will be closed circuit (turn the fans on)
If the pressure switch is over 247psi, but the trinary switch is between 247psi and 305psi, then the fans will run at slow speed
If the pressure switch is over 247psi, and the trinary switch is over 305psi, then the fans will run at fast speed.
On my vehicle static tests the Nanocom showed the evaporator temp going down to 1 degree and the pressure would have risen, the clutch dropped out and the temp rose to 10/12 deg area and the clutch pulling back in to continue the supply of cold air at the dash vents.
At the same time the fans came on slow as the pressure in the system increased and then to high. Once the system went back to the evaporator temp in the 10/12 deg region the fans switched off.
So is there some other input the causes the Hevac to cut the power at pin 7 that I have not seen in the wiring diagrams?
Andrew
No, even the description in RAVE isn't strictly correct. If you look at the diagram, the single pressure switch connects the HEVAC to the engine ECU which then sends a signal to the fusebox to bring in relay 18, the AC control relay, which turns on the condenser fans at slow speed.
From the Nanocom HEVAC document:
Air conditioning grant: When the A/C button is pressed an active low signal is output to the engine management ECU (The Request). This then looks at factors like engine temperature, load, current acceleration etc. and according to when these conditions allow, grant Air conditioning. This involves it engaging the clutch to drive the Air Conditioning pump, altering its internal fuelling to compensate for the load imposed by the pump, managing along with the Hevac, the Condenser fans, and also telling the Hevac that Air Conditioning has been granted. (even though the AC is on all the time EXCEPT when the button is pressed.....
Looking at that, you are seeing the AC Grant signal but from where? HEVAC or GEMS ECU? It appears that the HEVAC needs to send a request to the ECU which then sends the AC Grant signal as long as the ECU is happy for that to happen which then causes the HEVAC to send 12V out on the compressor clutch from pin 7. That means it won't try to engage the clutch if the engine isn't running or if it is running very hot and adding extra load wouldn't be a good idea. It isn't clear which is which but pins 28 and 29 on the GEMS ECU are the two that deal with the AC, so one will be looking for a ground from the HEVAC (the request), while the other puts out the Grant. The two connections at the HEVAC that go to these two pins are on the Black/Grey wire from pin 13, C246B and a Yellow/Black from pin 8 of C244 (which has the single pressure switch in line with it). However, even that isn't clear as the diagram shows the pressure switch to be open at less than 13 bar and closed at above 17 bar so at static pressure (without the compressor running) the pressure would be down at around 8 bar????
The trinary switch contains two separate switches, hence it having 5 wires to it. One is a single on/off switch which is the one that causes relays 13 and 14 to engage and put the fans on high speed if the pressure gets up to 21 bar. The other switch within it is the 3 way switch which is open circuit if pressure is below 2.4 bar or above 30 bar. So it won't allow the clutch to engage if the refrigerant is low or if it is over-pressuring.
The evaporator going down to 1C is too low and it will almost certainly ice up, that will cause the pressure to increase pretty dramatically which is why the clutch is dropping out. I suspect ice will be forming on the outside of the Low side (thick) pipe and the high side (thinner) pipe will be too hot to touch. When running normally, the evaporator temperature should go down no lower than 4C, at which point the compressor clutch will drop out until the temperature gets up to around 6-7C when it will kick in again.
Thank you Gilbertd. It will take me a bit of time to try and take all of your excellent description.
