380C might be better as it is rated at 200psi and not 150psi like the 350C. The pressure switch should cut out at 140psi so a compressor only capable of 10psi greater might be a bit marginal.
Done. Found one for £175.00 including shipping.
Here, belatedly, is the pic of the cut-out thermostat stripped from an old pump.
I glommed it onto the outside of the pump with epoxy putty.
