Trying to track down various oil leaks on brother's 1999 P38 Diesel which we are slowly addressing but found one on the injector pump that has only started recently and not sure how to fix it. There is a "cover plate" with cable attached, on the side of the pump above the main body with four screw fixings that looks like the gasket is leaking. Anyone know if it is safe to take this off and replace the gasket???? Cheers Mike
https://youtu.be/KQPSwtfP1Us
it can be done just watch the video a few times
Thanks for the response. We've been driving the old lady for a week now - monitoring daily and it seems that you are right. Repair kit has been ordered. The video link is excellent and helped to convince brother that it was the problem. Thanks again, Mike
juts remember to mark the too of the pump with the engine when you take the top off the way you can line it up nd shouldn't have to use a dial to reset the pump
