Further to Dave’s comment in this thread https://rangerovers.pub/topic/3016-ac-leak-test-at-home?page=2#pid38452, I’ve had a bit of time on my hands today. The car is ready and loaded up so I’ve spent the time waiting for Dina to finish work so we can set off before driving to Spain to write this.
I would like to think that at least some of you understand how the AC system in your car works, but in case you don’t, a little explanation. Everything has 3 states, solid, liquid and gas, the only thing that differs is the temperature that they change from one to another. Water, as we all should know, has a boiling point of 100C, the temperature where it changes state from liquid to gas (and 0C when it changes state again from liquid to solid, aka ice). However, if it is under pressure, the boiling point increases. That is why your cooling system has a pressure cap and the increase in pressure means it doesn’t boil (change from liquid to gas) until around 120C. That is why, as long as you don’t have a leak anywhere, your cooling system can run at 105-110C without boiling. In the same way, if you run on LPG you fill your tank with a liquid (Propane in this case) at around 10bar (145psi) so it remains a liquid but, as Propane has a boiling point of -44C, as soon as it is no longer under pressure, it becomes a gas.
So, what does this have to do with AC? Because it uses this to move heat from one place to another. It is filled with R134a gas, Tetrafluoroethane (CF3CH2F) with a boiling point at atmospheric pressure of -26.1C. Your system also has what are termed a low side and a high side signified by the pressure in the system. Starting at the low side, the system is full of a gas at a pressure of around 2.6 bar when operating. That gas passes through a compressor which raises the pressure to around 10.3 bar (at the High side) at which point it is fed to the condenser (the one in front of the radiator, the one that leaks with monotonous regularity) where, it condenses and becomes a liquid. That generates heat which is dissipated by the airflow though the condenser. This liquid then passes through a small orifice where it vaporises as the pressure drops on the other side of the orifice and goes through the evaporator (see how the names of the various components start to make more sense now?). At this point it gets very cold (although strictly speaking, in thermodynamics there is no such thing as cold, only a lack of heat, so the correct terminology is that it ‘draws heat’, something it took me ages to get my head around when I did the FGas course) in the evaporator, air is blown through it and that is the nice cool breeze you should get out of your vents. At that point the cycle starts again as the gas gets to the compressor to be compressed and turned back into a liquid. This is just the same as a Calor gas bottle getting condensation or even ice forming on the outside if you have your barbecue/patio heater/ blowtorch running flat out for a while. The liquid in the bottle is vaporising so is getting cold (sorry, drawing heat).
OK, so that is an automotive AC system and a domestic AC system works in exactly the same way. You have the compressor and condenser in a box outside your house (along with a load of control electronics). That is linked by two copper pipes (liquid and gas) to the indoor unit. These come in a variety of forms but the most common ones are the wall unit, the rectangular box on the wall up near ceiling height, or the ceiling cassette, the square units set into the ceiling that (usually) have 4 outlets blowing the cold air out in different directions. There’s multiple different designs but they all work in the same way. The big difference between a domestic system and that in your car is that they are reversible. The flow of the refrigerant can be reversed so the condenser becomes the evaporator and vice versa. That way, when the flow is reversed, the indoor unit gets hot and the outdoor unit gets cold. That way they can provide heating as well as cooling. Different units differ in how they achieve this, with some of the cheap Chinese made systems you have to manually set them for heating or cooling. The better systems, like the Fujitsu units I prefer and install, have an Auto setting. You put it on Auto, set the temperature and it reverses the flow as and when it is required. That way you can set 21C and no matter if the ambient is -5C or 30C (or higher as it has been recently in some areas), it will automatically maintain an indoor temperature of 21C.
On a decent quality system working correctly, with an ambient temperature of 25C when set for maximum cooling, the air coming out of the indoor unit will be down to 2-3C. When set for maximum heating, it will achieve 55-60C. If the ambient is cooler, this will be a bit lower but the Fujitsu systems will still provide 50C down to an outdoor temperature of -15C. This is spread around the room by a fan so is much the same as using an electric fan heater. The big difference is that it can achieve the equivalent of 3kW of heating (or cooling) while only drawing sufficient electrical energy to power the compressor, which will normally be around 600W, making it a cheap way of heating a room. Multiply that by the number of rooms in your house and it adds up to a considerable saving. The outdoor units can supply a single indoor unit or up to 8 but the install does get pretty complex…….
That brings us on to air source heat pumps (or ground source heat pumps for that matter, they work exactly the same). They are configured just the same as an AC system when using it for indoor heat as they aren’t reversible. The difference being that instead of giving a source of heat which then has air blown over it to distribute the heat throughout the room, a heat exchanger is used so that heat is used to heat water which is then sent around the existing pipework to your radiators.
This is where the problems start. First of all you have in inherent loss in the heat exchanger dropping the water temperature down to around 50C, many of the more modern houses have 10mm microbore pipework, perfectly adequate when the water is being pumped around from a gas boiler at around 70 degrees but too restrictive for water at a lower volume and 20 degrees cooler. Then a radiator will have been specified for the size of the room. Radiators tend to be specified in Btu’s (British Thermal Units), as are many AC units. You take the volume of the room in cubic feet, multiply by 5 and that gives the size of the unit or radiator you need in Btu. So an average living room or bedroom of 5m x 4m with conventional ceiling height is 16.4 ft x 13ft x 8ft, giving a volume of 1,705 cubic feet. Multiply by 5 gives 8,528 so I would install a 9,000 Btu AC unit. Radiators are also rated in Btu but that figure assumes they are fed with water at 70C and at the sort of flow rate achieved by a central heating pump. As the water from a heat pump is cooler and the flow is lower, in virtually all cases larger radiators (and often pipework) need to be installed. This is why people are having to spend in excess of £20k for an installation only to complain that the house isn’t as warm as it was with a conventional gas boiler. Radiators aren’t that efficient anyway, as all you have is a hot spot in one place in the room and the heat is spread mostly by convection with a little by radiation. That’s why it is recommended that the insulation properties are improved, to keep what feeble amount of heat you have from escaping.
Is it cheaper to run though? No not really. Let’s take the average 2 storey, 3 bedroom house. You’d be looking at a footprint of roughly 30ft square, so that is 900 square feet per floor so 1,800 square feet floor area. With 8ft ceiling height, that means you need around 72,000 Btu in total heating capacity or 28kW equivalent. OK, so AC units and air source heat pumps are pretty efficient so won’t be drawing that amount of power, but they will still draw in the region of 6kW as there’s one serious compressor in there (anything over a conventional house system will need a 3 phase supply). At today’s average electricity costs of around 30p per kWh, that’s £1.80 for every hour it is on. Not that cheap compared to a gas boiler, even at today’s prices, without taking into account the purchase price and the modifications needed to what you already have.
The only time a heat pump system will work adequately is if you have underfloor heating (and walking on a floor at 50C is a little more comfortable than one at 70C!). Although even then I have installed an AC unit into a house with underfloor heating fed by a heat pump as it would kick in as soon as the temperature dropped but if, after a couple of days the sun came out, it would switch off again. The owner of the house wanted AC to fill in the gap between the weather getting cold and the underfloor heating starting to work properly and also to give him the benefit of cooling in summer.
The irony of the whole thing is that you can get a Government grant of up to £5k to install a heat pump and they have a lower VAT rating too reducing the cost to buy and install. Although as they are so damn expensive in the first place there’s still a considerable outlay, particularly when you consider you can replace an existing gas boiler with a more efficient, modern one, for a couple of grand. But, even though it works in the same way and is probably better in many cases, you can’t get a grant for AC (and the systems are still rated at 20% VAT) as it gives you cooling as well as heating, so you are getting a bonus which the Government won’t pay for.
Personally I think Hydrogen fuelled boilers are the way to go but technology moves a lot faster than Governments so when they first made their recommendations that we should all be going for heat pumps, Hydrogen fuelled boilers weren’t around. Much like how they advocate we should a be driving battery electric cars when hydrogen fuel cell powered ones , or even a near conventional internal combustion engine running on Hydrogen, seem a much more viable, and ecologically friendly, option.
That's really interesting Richard, thanks for that!
It is an interesting subject.
I wondered about setting up a makeshift system for the house or caravan using car parts... possible? I could work it out but if you have the answer already you'll save me the job lol - How powerful an electric motor would be needed to drive a car AC compressor? I know another motor or 2 would be needed to push air through the evaporator and reducer. Maybe use Hanson quick release fittings to make for a portable system?
For the domestic systems (and I suppose EV systems which can also supply cold air or heat?) how is the system reversed... Surely not as simple as reversing the pumping action / spinning the motor the other way?
I would guess that it would only work if you had a very small room although a caravan might be OK. When you consider the volume of air in a car versus a house or caravan you will know why the compressor is so tiny compared to that in a domestic A/C unit.
Your usual excellent techno-commercial intro/analysis: Thanks Richard !
'For my sins' I have discussed such issues - or at least tried to - with local Council officials and even MPs; Almost universally they seem unable to grasp the basics but are 'happy' to implement whatever "the Law/Rules dictate/decide" of course... Oh dear: Might send them your summary instead now though....
In the meantime some of my over-heated neighbours are happy it seems to buy a big plastic box with a fan in it.... merely cooled by 10L of cold water. That's TV ads. for you though, and 'only' £200 (!). A few have the free-standing (proper) A/C units with a tube out of the window (but then they panic about night-time security). Some even have A/C with an 'ugly' external box.. Accordingly the type of heat-pump with large vents through the wall (ie. nothing external) seems ideal but even then they think an enclosure 1X0.5X0.5m is 'too intrusive'... There is definitely a shift in such thinking since 40C hit us recently though... as aesthetics 'go out the window' (!) when folks can't sleep.... ?
Lgpc: As a fixed A/C installation does not have the advantage of forward motion (ie. cooling air over the condenser so you need a big fan instead, as you mentioned) then an electric motor of 1 or 2 kW would probably be needed (or say about 2HP in old money) ?
My daughter had one of those, a total waste of money, even if you fill them with ice.
Not proper by any stretch of the imagination. They also seem to use the Italian horsepower/Chinese stereo makers output rating type of information in their specifications. I measured up a bedroom for a customer and it came out at needing a 7,000 Btu unit which surprised the customer as he had used a 9,000 Btu portable and it hadn't been capable of keeping the room cool in hot weather. Not only did the unit I installed cool the room but if the door was left open it cooled half the house.....
So how else do you house the condenser? Even if the customer wants it, I will not fit the outdoor unit on the front of a house. Hide it round the back or down the side where it can't be seen.
That isn't a heat pump but a heat recovery system where the heat is extracted from the room and used to provide hot water. The external box for a heat pump is considerably larger, usually with two fans, than the one for a smaller AC system
Big fan not needed, think about it, there's very little airflow though the condenser when sitting in traffic, and it doesn't really matter how hot it gets (within reason). The place where I did my FGas course also did the automotive course and had a test rig for training that contained everything you would find in a car except for an electric motor to drive the compressor instead of the engine. I'll give then a bell and see what motor it needs when I'm back in the UK.
Some of those heat recovery systems (Greenwood make one of them fitted to new builds) are designed to provide ventilation whilst minimising heat loss, they consist of some pipework, a heat exchanger and a large polystryene covered box with a condensation drain on the bottom of it. I don't think theres any moving parts involved in them from what I remember, though I think they must have a fan somwhere in the system.
Typical use for them is in new builds to suck air out of the bathroom/kitchen and replace with fresh air whilst keeping as much of the heat as possible through the heat exchanger. The box on them would typically be installed either in the airing cupboard area, or loft space.
Edit - should have made clear, most of the reason for this system appears to be avoiding damp by improved ventalation rather than heating, whilst minimising heat losses.
I briefly did some work on them on a contract a long time back between other work, fitting a modifiication to them on some new build properties.
How are the systems 'put into reverse' to switch between heating/cooling a room? Does the motor spin the other way / done by changing which jets the refrigerant flows through / valve arrangement on the pump and/or evap / condenser? Are they by design more efficient at heating or cooling a room (and jumping the gun a bit maybe - are the evaporator and condenser the same size, even perhaps the same part number?).
Richard: Thanks: Briefly, some clarification:
That 'only £200 cold water box/fan' nonsense is of course 'well dodgy' - probably as far as the ASA is concerned of course; You may as well just fill a hot water bottle with ice water.... ?
By proper A/C above I probably should have said "proper" ( ie. with inverted commas ) - simply as it has cold out one end and hot out the other.... and that is is at least externally vented
As for the 'heat pump / conditioner' I mentioned without external box it was something very similar to this (and only 1K fitted ...): https://www.appliancesdirect.co.uk/p/a1%2fiqool-smart12hp/electriq-a1iqoolsmart12hp-air-conditioner
Of course I agree that an external box will be (functionally) best, again it is just that aesthetics certainly affect folks' buying decisions.... not just my neighbours. Ask a woman !? Fan noise is key too. Some expect if to be almost silent "like the one in my office building..." (!!)
As BrianH said New Builds/New Regulations may mean house design needs to change.... along with expectations.
The main point is that there is definitely a real need for Customer/Consumer education on all this though: I have lost count of the number of folks asking me questions like 'why their whole garden needs to be dug up' for a Heat Pump Installation...? usually because they have (only) heard about Ground Source kit: Perhaps the BBC could oblige instead of all their celebrity baking/dancing/etc twaddle; I won't be holding my breath.....
It's basically a fan that blows the air over cold water or ice to cool it, better than nothing but not by much and certainly not worth the money.
Those things are noisy as they have the compressor, condenser and evaporator all in the one box inside the house. They work well enough (although not the ones with ElectriQ on the front), better than the portable units, and are an option if you can put up with the noise and have a reason why you can't site an outdoor unit.. The ElectriQ units are sold almost exclusively by Appliances Direct (and their other identity, Aircon Direct) and are horrible Chinese made units that look good (ish) but aren't particularly good or well made. They are cheap for a reason.
They are almost silent as they are the same units as fitted in office buildings. Often, the units installed in offices are more industrial so noise level is considered less important anyway so are noisier than ones intended for a domestic install. Indoor unit noise level of the units I fit is 20 dB(A), while the outdoor units are about the same.
Rather than putting an indoor unit into every room making the install complex (and expensive), the way to do it on a new build would be to incorporate ducts (or use the void space between joists) so a ducted system could be installed. This uses a single indoor unit (or one per floor anyway) that lives in the attic or in a service cupboard and outputs via vents installed in each room.
A ground source heat pump will work much better than an air source one as the ground temperature remains reasonably constant a few feet down. So while the air temperature can vary anywhere between -10 and +35C, 10 feet down, the temperature will probably be between 5 and 10C and won't change much at all. So when you are using this as a source for the evaporator (in the case of a heat pump installed for heating), it is far more reliable as the temperature differential is constant. Downside of course, is that you need to dig up a large quantity of the garden (if you have a garden in the first place, not the postage stamps that most new builds come with these days).
@LPGC. Having remembered the question and waiting for the delivery of the units for my 51st install since starting this lark, I called the tutor at the training place where I did my FGas. He had a look at his automotive test rig and the motor used to drive the compressor is a 2.2kW, 3 phase motor, so pretty substantial (which probably explains why the idle speed drops on some smaller engined cars when the AC clutch kicks in).
He was sceptical that a system from a car would be sufficient to work in a caravan. You have to remember that the important thing when sizing a unit is the volume of air it is expected to cool. So a system removed from even a large car like a Jag, is still only intended to cool a much smaller volume than a caravan. If you have a system removed from a campervan that would probably be OK (as the volume will be much the same).
Thanks Gilbert
How are the systems reversed (heat / cool a room) ?
The idea of switching to heat pumps for domestic heat isnt to save money, its to stop burning stuff. Seperate issue really. Nox is a problem in big population centres and domestic boilers produce a vast amount of it, hence the moves to ban them, much like similar moves for automotive applications. Hydrogen only looks good from the viewpoint of how we do in now (a pipey-flamey-burny-heatbox), its a horrible solution when you look at the wider picture. Clearly manufacturers of flameyburneyboxes are going to be championing the thing that keeps them in business. Electricity is great because it comes from many sources. your heat pump can be powered by gas, or solar, or nuclear, or wind, or hydro, or diesel, or coal. A gas burning machine can only use one source. Your electrical machine gets cleaner over time as the grid installs more renewables, Your gas burning machine doesnt.
As for the operating cost, its quite simple. A heat pump operates at a COP between 3 and 4. This means it will move between 3-4kwh of heat for 1kwh electrical input. Thus if we want 15kw output, we need say a 5kw heat pump. But it also means we can easily calculate the cost of 1kwh of heat energy. if the electricity costs 30p/kwh, your 1kwh of heat output costs about 10p at a COP of 3, and ~7.5p if you get nearer 4. The exact operating point depends largely on outdoor temperature and humidity.
Gas currently costs about 7p/kwh. So at first glance gas is cheaper. The gap closes slightly when you consider that the boiler isnt 100% efficient and while manufacturers claim upwards of 95% the reality in a house that needs 70c water might be closer to 80%. the high figures are only achieved if the boiler can condense at maximum efficiency, which only happen when the water temperature is within a tight range. Just like a heat pump, if you retrofit a modern boiler to an old property that requires high flow temps, it wont condense properly and wont be as efficient as it could be.
So at 7p gas, 30p electric, you probably just about break even. At some points when the heatpump is running nearer a COP of 4, it'll be ahead, and at other points when its down near 3, and the boilers operating maximally efficient the gas will be slightly ahead. Its disingenuous to simply state the heat pump will cost £1.80 for every hour its on... My Gas boiler can peak at 38kw, so based on 7p gas it consumes £2.66 for every hour its on. But physics doesnt work like that. The heat input is equal to what comes out the other end. Wether its a gas boiler or a heat pump, the heat required to heat the home is the same. Neither system will run at full power continuously, they'll modulate their output to match what the radiators are extracting from the water. Thus the important figure is what it costs to produce that heat.
One advantage going electric is you can use time of use tarriffs, to shift some of that heating load. A friend of mine has a heat pump and an underfloor heating system. The pump runs over night off peak, consuming electricity at 7.5p/kwh and heats the floor slab. The slab then warms the house throughout the day. Clearly not an easy retrofit, but you can do similar with your hot water heating for example, using the heat pump off peak to heat the water tank. Some installations also have a large buffer tank for the heating, so again you can heat the tank cheaply overnight, and then pump the hot water out to the radiators when you need it.
The big problem i see currently is massively ripoff pricing. Heat pumps arent cheap, granted. A Gas boiler might cost a grand and a heatpumps more like 4-5 grand. The problem is the installers want to rip you off to the tune of 10 grand for an "easy" job, and or closer to 20grand for a "difficult" job. Clearly nonsense, even when compared to the already rip-off price a gas fitter charges to install a boiler.
My personal approach is pragmatic, i have a functioning gas boiler, and an older house thats needing redecorated top to bottom over the next few years. So as i decorate each room, i'll specify a new radiator which will correctly operate at a low flow temp and meet the heat requirements of each room. I'll also adjust any pipework as i go, to remove the microbore sections etc. This has two benefits, one it means i can run the gas boiler at a lower temperature, improving its efficiency, and secondly it means that a few years down the line, the house will be "ready" for a heat pump when the boiler expires.
Agreed, but you'd need to be a pretty fervent tree hugger to do your bit for the environment but at the same time increasing your costs. If someone can see that a replacement system will be cheaper to run and recoup the initial installation costs over a reasonable period, then they will go for it but if it costs more to install, roughly the same to run and doesn't work as well, then why would anyone go for it?
However, there are now also electric boilers on the market that can be installed as a virtual straight swap for a gas boiler. Allegedly very efficient but I can't see them being cheap to run.
My AC systems have a COP of between 4.3 and 4.7 depending on the exact unit so we are talking roughly the same. I quote the following to potential customers for running costs based on my own energy tariffs:
Typical running costs for 2.5kW (7,000 Btu) based on electricity at 29p per kWh and 7.3p per kWh for gas
Electric fan heater or oil filled radiator approx 73p per hour
Gas boiler at 70% efficiency (10 years or over boiler) approx 26p per hour, at 90% efficiency (new modern boiler) approx 20p per hour
AC system approx 16p per hour.
Assuming a heat pump system working at a similar COP to an AC system, even initially it looks to be cheaper but all, except maybe the electric fan heater, will modulate the operation as required once the room(s) is up to the desired temperature. A gas boiler switches on and off whereas the heat pump and AC systems will slow down but the duty cycle will still reduce. How much of that is done will depend on the insulation properties of the building. If you are generating heat but then allowing it all to escape, the heat source will need to be on for longer. I installed an AC system in a garden office for a customer in January last year. He left it on 24/7 from the day I installed it until June and it worked out at 3p per hour according to his Smart meter. He was so happy he got me back to install another in his recently extended kitchen!
Digressing slightly but initially I was installing AC systems in garden offices, garage conversions and summer houses being used by people working from home as a result of lockdown restrictions. This is another advantage with them that they can be installed as a stand alone system in a location that can't easily be connected to the rest of the heating system. More recently, perhaps as a knock on from lockdown, many people have been building outdoor entertainment spaces in their garden. A larger summer house type construction but with a bar, TV, sofas, etc, a place for a party without taking over the house.
But for how long will that situation exist? With the push towards everyone having a Smart meter, the energy suppliers can see when you are using the bulk of the energy. With more people using the cheaper 'off peak' tariffs to charge their EVs, run their heating, set their dishwasher and washing machine to run at night, etc, how long will it be before the daytime is off peak and the night time rates increase? My problem with Smart meters is that the push for them is that you can save on your costs. You can but only if you consciously do something about it. You can run around the house switching things off to save a few pence or you can say f*** it, I'd rather spend the extra and be comfortable.
Same everywhere though. My prices work out on average to roughly £8-900 per room for an AC system but I've had customers that have had quotes from other installers that are over twice that (and bear in mind I'm still making around £300 a day on a single install) for example, charging the customer full retail price for the units, so much for installation and a further charge for testing, commissioning and certification. They don't pay full retail for the units and the testing and commissioning is simply the final part of the installation as far as I am concerned. I suspect the heat pump suppliers are doing exactly the same.
And that is the way to do it. Adding insulation is another option that will reduce your costs in the long run. The differences in construction over the years mean some properties already have it but others will benefit greatly. I think I've found most of the different types while putting a 65mm hole in a wall for the pipework. Everything from solid walls without even an air gap, through to new builds with plasterboard, a 20mm air gap, 100mm thermalite blocks, 50mm of fibreglass and finally external brickwork (and even that is hollow). The worst I encountered was cavity wall insulation using polystyrene beads. Drill though one layer and end up with an avalanche of little white beads that go everywhere!
I know it wouldn't be in the environmental spirit but could it work out cheaper (than using electricity) to drive the heat pump using an efficient engine fuelled by mains gas? It would also be possible to make use of the coolant heat (instead of having an engine radiator) and the exhaust heat.. Could maybe even run an alternator from the same engine to get cheaper electricity too.
Heh, thought once occurred that maybe it would be possible to claim to have had solar panels fitted (while not actually spending any money on them because none were bought), set up a genny running from mains gas, sell the leccy it made back to the grid (feed in tariff) claiming it was produced by solar panels.
Both of the above taking advantage of the kwh price difference between mains gas and electric.
Ha ha. That would be analogous to having an electric car and towing a diesel generator behind it.
Can I chip in with some of the figures quoted (purely anecdotal). Before I retired I used to visit the States on a regular basis. Heat pumps have been common there for a long time, particularly in rural areas. In the UK we lagged behind because of the availability of cheap gas (past tense).
They can also be reversed to cool the house in summer.
Speaking to fellow engineers, they reckoned an air source heat pump gave about 5:1 ratio and a ground source pump about 8:1.
Another bit of useless anecdotal information, a near neighbour where I live had a ground source heat pump installed several years ago with a vertical shaft in his back garden. When they had the drilling rig on site, he did a deal with the guys to drill down another 150m.
He tells me he has kept detailed records and he is getting between 10:1 and 11:1 ratio.
That is the difference between EER (Energy Efficiency Ratio) and SEER (Seasonal Energy Efficiency Ratio) and COP (Coefficient of Performance) and SCOP (Seasonal Coefficient of Performance). As the efficiency will change with the difference between indoor and outdoor temperature, the seasonal figures take this into account by using a fixed indoor temperature with a varying outdoor temperature and averaging the result. EER and SEER are the differences between energy consumed and energy output, so a unit that draws 1kW to solely convert the energy and outputs 4kW has a EER of 4, whereas COP and SCOP are the output minus the input (the power used to convert the energy but also that used to supply control electronics) so that same unit would have a COP of 3 (4-1).
My other half works for Cummins and they have supplied a large number of big diesel generator sets to Australia to power remote EV charging stations......
I was going on the cost per KWh figures, 29p for electric and 7.3p for gas.
Most of an engine's inefficiency is due to wasted heat (pumped out of the exhaust and sinked to atmosphere via the cooling system) but that heat need not be considered an inefficiency if the objective is to produce heat for heating and it can be captured.
Assuming the generator would be only around 33% efficient (gas KWh in to electric KWh out) it would be possible to generate electric at 21.9p per KWh, which in itself would be cheaper than buying electricity from the grid before even before thinking about making use of the heat that the generator's engine produced that would normally be wasted. Use the electricity generated to power a heat pump and make use of the engine/exhaust heat to heat radiators / hot water tanks directly.
I.e. Due to the difference in cost per KWh (gas vs electricity), for same cost we can use nearly 4 x as much gas as electricity. So even if a generator is only 33% efficient it still works out cheaper to make our own electricity at home using the genny than to buy it from the grid. But then the 67% usually considered the genny's inefficiency can be put to the same useful application as gas boiler.
The 'generator' wouldn't necessarily even need to generate electricity, it could run the heat pump directly from the engine. Unless you want to produce a lot of cheap (compared to grid price) electricity, maybe to charge an EV or large household battery powered invertor system from.
Burning gas is the most common method the UK grid uses to generate electricity anyway and they make a profit burning gas to make electricity to sell to you despite grid transmission losses (all those power lines and transformers waste heat to atmosphere).
