Seeing as I'm about to be replacing the gearbox on the DSE I was thinking of flushing the oil cooler. I don't know what's gone wrong in the old gearbox and I don't want to risk any more damage then necessary by any crap that might be floating around in the oil system.
I've been looking on Google and found a video on YouTube of Eric The Car Guy flushing an oil cooler using a can of spray solution.
Video of cooler flush
I can't find anything similar in the UK so I was wondering about flushing it backwards with ATF or possibly Diesel, I just wondered if anybody had any suggestions or ideas.
Thanks
David.
Acetone should do the trick. Evaporates nicely too,
I know that Ashcrofts strongly recommend it. It is the main reason for gearbox failure after a rebuild.
I would have thought petrol via a rubber tube and funnel first to flush any metal bits out.
Diesel fuel - anything else as above is probably too volatile/thin.... !
( I use it for engine flushing, or even paraffin will work fine for that matter...
the proprietary stuff is just hugely-overpriced petroleum-based nonsense)
