Yep, the nut turned a good amount, but it seems to be stuck right towards the end of the bolt. Wouldn't budge when twisting with my hand.
The 14mm socket worked well for every other bolt, but it's been awkward on this, so I'll try with 13mm.
Good news is the propshaft is off - I can now move the car in drive.
What is still left is to test the VC to determine if it's seized. I tried a bunch of variations (rear wheel up, handbrake off etc), so I can't remember what the setup exactly was, but I was able to move the VC, by hand, ever so slightly before it stopped - as if it now required torque for additional movement.
I was able to move the car back and forth with no grinding noise at all - could this be any indication that the VC is 'ok'?
I'm going to attempt the bolt once again as my propshaft arrives today. Doesn't help that I lost one nut somewhere next to the car.
The nut, or the thread on the bolt has probably been damaged when the broken UJ flew out from under the car. Last resort would be to use an angle grinder and cut it off but that would then mean you will have to take the output flange off the transfer case to replace the bolt.
The viscous coupling is a sealed unit filled with a silicone gel so you won't get any noise from it. Driving with one propshaft missing is a sure fire way of causing it to seize even if it wasn't already (which it almost certainly was). It connects the front and rear propshafts so you need to stop the rear from moving, either with the handbrake or with the gearbox in Park and the rear wheels on the ground. Then you try to move the front, usually by lifting one front wheel and seeing how much torque and over how long, you can move it. But that does assume you have a front propshaft connected. As you don't, you will need to do it with a socket and breaker bar on the nut in the centre of the flange the propshaft fits to.
New bolts have arrived but EVRi decided to lose my propshaft..which was due on Wednesday.
When bolting in the new propshaft, is it a straight 'bolt-on' job? I'm reading things online about balancing, etc, and how those can feel vibrations as the propshaft was not 'aligned'.
Also, the vehicle no longer goes into park - is this expected or another issue?
what i done with mine was lined up the weights on both props and bolted up if it vibrates just move it round one hole each time
as for not being able to select park the old prop might of hit the selector on side of gearbox just get someone to sit inside and select P while you look at the selector and see where it catches i had to bend mine back slightly with a bar when same happen to mine
The prop may be a simple bolt on job as long as it is phased correctly. The original one had a spline missing on the sliding joint so it would only go together with the UJs correctly phased. Some aftermarket ones didn't have this so could be assembled any way so could be wrong. If you have the version of RAVE that includes the Classic, that has a picture of the correct phasing.
So, I finally was able to grind the nut. It was so awkward as I was protecting my face. I’ve called it a day as my wrist was well worked.
Anyway, yep. I need the one bolt off which means removing the front flange.
https://share.icloud.com/photos/03fNoxtgZp9bIsMIgSSOvL5Eg
Having said that, I require probably half an inch to safely push it out. For tomorrow, is it worth moving the car ever so slightly to find a gap to push the bolt out, or is it as straightforward as using a 30mm socket with my impact gun to remove the bolt and do a quick swap? (I’ll shoot myself in the head if only a breaker bar with work here. I’ll accept defeat and find the nearest garage)
If the latter, my only concern is applying excessive torque with the impact gun, so I’ll use a permanent marker to mark the current bolt position before reapplying the bolt with small incremental taps with the gun.
I’ve reached a big blocker - https://share.icloud.com/photos/0a1OQ5v6pxKKJuteKQutqsADQ
You probably need to take the dust shield off ?
I ended up grinding a bit off the lip to be able to get the bolt in. Finally, this job is done.
Now, to test if the VC has seized.
Maybe I’m being paranoid but I’ve had the car washed and this is how the same end that was worn looks after a 100mile drive.
https://share.icloud.com/photos/04323Accl77386efkKRlIanrg
I’ve had the alignment done yet the steering wheel is still slightly bent. I conducted one VC test of driving in a slow circle full lock either side, no noise or struggles of the tires.
So the issue is still present. Is the VC the culprit here?
Not sure what the picture is showing other than a tyre? There's two stages to the alignment, the toe in/toe out is adjusted with the tie rod behind the front wheels but the centralisation of the steering is done at the drag link at the front (between the steering box Pitman arm and the LH front hub) in combination with the centering marks on the steering box input shaft. The two adjustments are independent of each other. If the alignment was done using the 4 wheel alignment system with a laser and computer, chances are it will be wrong.
