I can't see the latest graph, Google says I need permission, I clicked to ask you for permission.
I can see the good Rover graph.
Done a bit of digging, apparently they do show comparative difference between aimed for and actual cam timing. But I'm not sure if the field names and units are correct in your readings, why does it show cam timing at 60degrees, shouldn't a base reading be close to zero degrees? I know cam timing can't really be 60degrees out because the engine wouldn't run as well as it does (or not at all, might even get valve to piston contact if it were that far out) but I'd be looking into why the data says 60degrees.
Fuel injection doesn't need to be very complicated and could be fitted to most old-skool engines for an immediate improvement over a carb in terms of power and fuel economy, also lets not forget lower engine wear due to decreased bore wash and the improvement in cold starting performance... As recently as the early 90's I remember having to help some people get their carb'd engines started in the works carpark but fuel injection made starting an engine turnkey in any weather conditions. When fuel injection first became common it was fitted on engines that were designed for carbs like the Rover V8's, Ford Pinto engines, etc, comparatively simple engines that an owner with some mechanical skills might be happy to dig into to change head gaskets and other big jobs. Fuel injection didn't really affect the simplicify of the engine itself, if you were happy to do the head gasket on teh carb'd version you'd be happy to do the head gasket on the fuel injected version. It's aspects ike VVT and complicated multiple cam timing chain setups that makes people who would once be happy to dig into an engine not want to dig into it... If you want to pull the head(s) on a modern engine there's nearly as much work involved in just removing the timing stuff than there used to be in the full job of pulling head(s). The VVT and 4 valves per cylinder do give the engine a flatter torque curve over its full rpm range compared to (say) a pushrod or SOHC engine but it comes at the cost of much more complexity for diagnosing valve train problems and work digging into engines... And you've got to wonder if it's worth it, because the engines are bigger for the same cubic capacity while the gains are probably only around 10% compared to a SOHC of same cubic capacity and those gains are mostly right at the top end of the rev range near the red line. In the same space as a modern VVT engine you could have a bigger old-skool engine that would make the same power and be a lot easier to work on.
I remember years ago when I had a different job, finish work at 6am after a night shift, drive the couple of miles home, have some breakfast, then think to myself shall I go straight to bed or shall I change the clutch in my car / whip the cylinder head off to fit the head I'd been flowing and had fitted a different cam in. Plenty times I did the work on my car then went to bed for a few hours before the girlfriend finished work and called round. Did the work just in the yard, no cranes or lifts, just had a jack and a few bricks, chain block bolted through a girder across the top of the garage door and set of tools. Relatively easy access to everything compared to modern cars. I used to buy/read magazines like 'Fast Car', people / kids would build and modify engines themselves. Then increasingly often there'd be articles in the magazines about someone who had built / modified a car but when you read into it they didn't actually do the work themselves, instead they through money at it and got specialist companies to do the work for them, some of them had probably never lifted a spanner lol.
