Put a new Hankook battery on yesterday as, after 6 years, the old one had decided it wasn't holding charge above 12.5 volts giving various "I'm not happy" beeps and messages.
Now the Alpine radio won't wake up. Power present on the connector and fuse is good. Is there anything else I can easily check or should I assume it's toast. Could have been dead for some time as I rarely use the radio. Likely a year or two since last used.
If it is toast the easy option is a radio from a breaker but not sure that £200 + is worth it for something I use so little.
.I have a brand new Kenwood KDC241 SA kicking about the place that would do for now. Powers up OK from the grey connector but obviously will need the outputs re-worked to suit the P38. Fortunately I have door amps, not DSP complexity, so making the mods is more tedious than difficult. Or can I buy something to just plug'n play. Mrs Google and E-Bay imply that such things might be around from the likes of InCar Tech et al.
If I'm going to do serious messing around the most attractive option is a large floating screen unit for a reversing camera and big navigation display. Pioneer SPA-EVO 950 DAB looks good to me but £600 for name brand reassurance plus a centre dash to rework makes it a serious project. I know the Android screens can work well. But which brand / supplier is good right now. I have never been lucky with affordable import electronics.
