I want to work on the steering wheel buttons and cassette. Is there any way to remove the airbag without disconnecting the battery? I've had key problems and don't want the hassle.
Also, is there a way to test the cassette? None of my controls for cruise, ICE, etc. are working.
Rave says to disconnect the battery and wait 10 minutes. I know a lot of experienced mechanics don’t bother and just disconnect and reconnect SRS plugs. Do at your own risk.
I've never disconnected the battery, just make sure ignition is off and the key is in your pocket. No power is no power no matter how you achieve it. Take the cassette out, tape it so it can't rotate and test for continuity from one end to the other.
Super, that's what I thought.
