My 2000 P38 Vogue is starts okay, after a minute or two RPM drops below 500 and is, understandably lumpy. This lasts for about 30-40 seconds, then recovers.
It's been doing it for a while but has recently become much worse.
MAF was replaced about 20k ago.
Mine would do that a couple of years ago. I found that if I switched off and restarted, it was fine. One day I had the Nanocom plugged in and checked for any stored codes and found one for the EVAP solenoid. Had a look at it and noticed one of the wires had corroded and pulled out of the plug. Found a suitable plug, soldered it to what was left of the wires into the old one and it hasn't done it since.
Found it. It doesn't look great.
EVAP Solenoid
enter link description here
Doesn't does it. I tried to edit your post so the picture appears but don't seem able to do it, so there's a click-able link now instead so others can see it. Moisture gets under the insulation and rots the copper so you end up with a high resistance or no connection at all.
