Hi all,
I've been trying to track down a leak into the cable channel by the drivers front door (next to the BECM). After a soaking with the hose I've found that the water is getting under the door seal and then dripping off into the channel containing the cables.
The seal is in good condition, pushed fully against the metal and is mounted correctly so I'm not sure how it's managing to get past the seal. New seals seem to no longer be available. Does anyone have any suggestions on what to try next? I guess glue or sealant is an option but I'd like to be able to remove it again in the future if needed so I'm not sure what type to use.
I usually use RTV
