You can see everything the the heating system is seeing on the Nano. Go to HEVAC, Inputs, Values and the screen will show you:
· Ambient temperature (c): This reading gives the external air temperature or air entering the ventilation system.
· Aspirator temperature (c): This reading gives internal cabin temperature.
· Evaporator temperature (c): This reading gives the evaporator unit's temperature.
· Heater core temperature (c): This reading gives the engine coolant temperature where the coolant enters the heating system.
· Road speed (Km/h): This value is generated by the ABS ECU using information from its wheel rotation sensors.
· Road speed (mph): This value is generated by the ABS ECU using information from its wheel rotation sensors.
· Engine running: Y or N
· Solar sensor (w/sqm): This reading gives the effective strength of the sun as detected by the Solar Sensor mounted beside the Alarm LED on the top of the dashboard.
· Distribution motors (%): This gives the current feedback position of the motor that drives the flap controlling air distribution inside the vehicle. As the distribution buttons are pressed the flap should move to the position which gives air flow to the selected direction (feet, face, screen etc.).
· Left blend motor (%): This gives the current feedback position of the motor which drives the flap controlling amounts of hot and cold air to be blended together (effectively the temperature of the air coming out of the vents). As the requested temperature is changed by the user the flap should move.
· Right blend motor (%): This gives the current feedback position of the motor which drives the flap controlling amounts of hot and cold air to be blended together (effectively the temperature of the air coming out of the vents). As the requested temperature is changed by the user the flap should move.
· Left blower return: This is the feedback value returned back to the Hevac ECU from the left blower motor, used by the ECU to determine the actual voltage at the motor. This reading value also allows the Hevac ECU to detect Blower motor faults.
· Right blower return: This is the feedback value returned back to the Hevac ECU from the right blower motor, used by the ECU to determine the actual voltage at the motor reading. This value also allows the Hevac ECU to detect Blower motor faults.
· Air conditioning grant: When the A/C button is pressed an active low signal is output to the engine management ECU (The Request). This then looks at factors like engine temperature, load, current acceleration etc. and according to when these conditions allow, grant Air conditioning. This involves it engaging the clutch to drive the Air Conditioning pump, altering its internal fuelling to compensate for the load imposed by the pump, managing along with the Hevac the Condenser fans, and also telling the Hevac that Air Conditioning has been granted.
- '98 Ex-Greater Manchester Police motorway patrol car, Range Rover P38 4.0, in white with a not very recently cleaned cloth interior
- '96 4.6HSE Ascot because you never know when you might need a spare
