super4 wrote:
Well I'm in good hands with Brian and Gilbert - just as a curious boy at back of class - tell me - If fuel is low and I do the 'reset adaptives' with my Storey EAS are you saying that the ECU says to itself 'Fuel low - ignore Adaptive reset' and therefore does not carry out any reset ? I'm sure that is a tricky one for you - expect you know though !
Easy enough for you to check. Read the fuel trims which are very unlikely to be 0%, or the adaptive FMFR and see what they read. Then do a reset and see if they have changed or not. If they haven't, then the reset hasn't happened, if they have, it has.
oilmagnet477 wrote:
You make an interesting point but to be fair, for the DIY'er at least, there is often no choice but to replace parts, therefore turning us in to unwilling 'fitters'. Many parts these days are not serviceable items and even if you can get them apart, finding spares is often tricky.
That's right but to attempt to service a part then you must have worked out what part is at fault. Particularly on something older without OBD connectivity you are down to good old fashioned logical faulting. It is this that is sorely lacking these days. The classic problem is a car that doesn't run right. OBD says the lambda sensor is showing permanently lean. Is this a faulty sensor, an air leak, a clogged fuel filter, a weak fuel pump. There's any number of things that it could be and in the old days you would go through a logical diagnosis process. You'd check for air leaks (spraying carb cleaner on all the intake areas), check flow through the fuel filter, check fuel pressure and flow through the pump and so on. If they all said everything was OK, you'd conclude the sensor is telling lies and change that. That logical approach seems to have been lost these days. With something running a carb, it was even more of a black art. Hardly anyone these days understands what goes on inside a carb and how the slow running jets, progression jets, main jets, accelerator pump, etc all interact with each other but that was second nature to the old school mechanic.
All running perfectly on LPG
