Hi folks,
So I'm replacing the gearbox radiator on my 4.6, and heat was required for the pipe connections.
The temperature sensor took a tiny amount of heat itself, so I'd like to test that its working correctly still.
Is it an open/closed circuit style thermistor or a resistance based one?
Its currently short circuit, 0 ohms.
Thoughts?
The dreaded oil cooler pipes, Mine stripped the thread when I changed mine..
From memory a closed circuit is correct,so you should be good to go..
I'd like to check it goes open circuit at a sensible temperature, any idea what the threshold is?
Oh well. Need a new one now regardless, it got guillotined in the replacement process. :(
