Got back in the early hours this morning from another trip over the Channel ('twas a bit bumpy too....) and on the way back I called in to see Teri (Mymisteri) just outside Paris to drop off a Hankook battery for her. Got there to find she had a slightly more pressing problem than a battery that wouldn't hold it's charge for more than a couple of days. Her car had started scent marking it's territory in a big way. She though it was a leak from the front diff as that was where the liquid was dripping from but a quick look underneath suggested it was from higher up. She started the engine and diesel was pouring down the side of the engine block. Took the plastic cover over the injectors off and could see a jet of diesel from the split bung on number 6 fuel injector. Replaced that with a bit of washer hose with a 13A fuse jammed in the end and tried again. This time there was another jet of diesel from a small hose running from number 1 injector to a banjo union on a metal pipe. These are what I think are the leak off hoses that leap frog from one injector to the next and all of them were perished and cracked along their length so need replacing. As she is an American female, living in France and driving a P38, she'll no doubt be charged about €100 for a set of pipes and 10 hours labour to replace them if she takes it in anywhere (not to mention having to wait at least a fortnight to get it booked in and done). Having seen the pipes she's pretty confident she can change them herself if she has the hose to do it. My local motor factors do a leak off pipe kit of a length of hose and a bung for the end but I seem to recall from the last (only) time I had anything to do with a diesel, there are different sizes. What size do I need to get so I can pick a kit up and bung it in the post to her? It's a '99, late EDC engine if that has any bearing on it.
