The condenser fans can be pretty much ignored - the viscous fan moves so much air even when the coupling is unlocked and its 'free spinning' that the pressure in the high side of the system is kept in check. The fans are controlled by the pressure switches - the single pressure switch when shorted (reaching 12 bar or something like that) turns them on at low speed. At 15-17 bar, part of the trinary switch will change them to high speed. At 30 bar, it cuts the compressor off to stop kaboom occurring.
The usual culprits would be the fan speed control transistors and blend motors... though if the speed control, blend flap adjustment and displayed temperature have all failed at the same time... it might be an issue with the HEVAC itself. Maybe...
Is the chequebook making itself known on the display?
                            Southampton with a Nanocom for Thor/GEMS P38s
1996 4.6 HSE, then became a 4.0, now cubed.
1997-8 4.6 HSE Motronic/Wabco prototype vehicle. Now M57 powered. Still auto.
