The distribution flaps should be moveable with very little force - the later heater boxes are obviously a bit different to the early ones, as you can move the distribution flaps on one of them with your little finger (yes, I was surprised too the first time!)
One thing with the HEVAC... it will ONLY actually clear the faults with the ignition cycled - so if you go in an clear the faults, it will say it's cleared them, but it won't actually erase them from memory until you power off and back on again.
Are the flaps/motors at one of the end points currently or set to middle? If they are set to middle, then it sounds like something else weird is going on. If they are at one of the end stops, then I'd reset them to middle (can move the motors with a 9V battery) as it could be that at the end point it's showing out of range on the HEVAC due to calibration.
Other things it could be... it could be the wiring being backwards on the connector. I fit a new set of blend motors to my RR not so long ago - I'll try and see if I got a picture during reassembly which shows the connector/wiring colours.
Another possible option is that it could be the driver IC in the HEVAC controller that has failed. It's a fairly rare occurrence, but it does happen. They are replaceable. One of the symptoms of them having failing is a constant error in the HEVAC with it telling that it is short to positive and possibly negative at the same time.
First thing to check though is how tight the distribution flaps are. Also, one of the sets of flaps can become disconnected from the drive, as the drive rod works it's way out the other side of the heater box (can only see it with maybe the glove box out, but definitely with passenger air bag removed.
There are possibly a few other places to check aswell - I'll have a think... I've done heater boxes/blend motors on 8 or 9 P38's now, and reconditioned more HEVAC controllers than I can remember - so I'll rack my brains and see if I can think of anything else..
oohhh, I've actually got a HEVAC on the bench that I need to finish testing (I have a P38 heater box with blend motors I use) - so I'll try and get a picture of the blend motor connector. I don't think anything is messed up in the firmware of the HEVAC controller - as I've tested everything from the early AWR1011/1012 through to the later JFC102540/102550 controllers with the same set of blend motors, and they've all reported proper values, and calibrated properly. I'll see how my set of blend motor wiring matches up with the RAVE wiring too.
