What are those things for ? Mine are the worse for wear, and I need some new ones...does anyone have a name for them? - or part code :o)
Oddly, I've just been asked about the same things by a man who has just bought a P38 with LPG conversion and found the spare wheel well around the LPG tank full of water. His are crumbling away too.
It is a drain point if water enters the wheel well. It might fill up full if wading in deep water.
No longer available I think unless a dealer has old stock.
I fitted a rubber blanking grommet instead.
Ah OK, so 4 big ones, and is the smaller one, by the screw-in stud for the spare, also removable? I don't want to try and pull it out if not.
Smart that they worked out how to drain the spare wheel well after wading but not protect the BeCM
