Hi All
Can someone advise of the required button presses to input the code on the attached radio (battery was removed for welding, and since the display doesn't work the owner can't tell if hes inputting it correctly or not). We think this is the Clarion unit rather than the Alpine one, but would be helpful to confirm that too?
I think its a case of press button 1 the required number of times to input the first digit, then 2 for the second digit etc, but not sure what you should be pressing after that.
I have suggested that he considers sending it to Clarion for repair and code removal, though I know Richard did say they were running out of replacement screens with the last one he sent away so it may not even be an option now. Also how can you tell which audio system is fitted (or to ask the question in a different way, is fitting a different stereo likely to be less than straightforward on a 1997 DSE due to amplifers etc, vehicle doesn't have any sub or similar kit but not sure if it has the door amps or how to tell?)
