I'm having more trials and tribulations trying to sort the 7S wiring socket on my VSE.
I bought a split charge kit from Land Rover (STC8875) which is listed as fitting all P38's from 1995 to 2002.
The instructions when looking at our GEMS car make perfect sense, you remove a bung from the pink plug under the fuse box and slide in a new contact and insert a 5A fuse into slot 35 in the fuse box.
When looking at the fusebox for my 2002 P38, there is already a wire in the pink plug and Fuse 35 is a 10A fuse for the fan.
After a brief chat with Marty last night, there is another way to wire it in but due to the kit it won't charge the battery in the caravan so I'd like to avoid this route if at all possible.
I've also found a 4 pin connector behind the rear left tail light. If you remove the plastic panel beside the subwoofer it's hanging there. From what I can see the 4 pins are:
Red/Green - Reversing Light
Pink/Red - Permanent Live
White/Orange - Switched Live
Black - Ground
Anyway, my question... does anybody here have a THOR car with the white 12S towing socket fitted? Does it just run through a bung in the floor into the connector behind the tail light or does it still have split charge and a volt sensing relay at the front of the car too? I really cannot find much information about the later cars online at all.
David.
