Good Day,
My 2000 RR is stuck at Access Height. I have no faults showing up.
Pressure is sitting at 58 lbs(the PO put a pressure gauge in the engine compartment). No leaks that I can see, hear or feel. The pump runs but doesn't seem to be filling the tank.
I have the RSW software and took a look at that today. There are no faults showing. I'm going to let the RR idle with a door open to see if this time it will build pressure.
But any ideas as to what is going on?
Thanks,
jastutte
