A couple of months ago my car developed what sounded like a whining diff. As I had replaced the rear not that many months previously it couldn't be that so I assumed it was from the front. There was a bit of up and down slop on the input and oil that did resemble metalflake paint so I figured that had to be it. Marty fitted new top and bottom ball joints to a spare front axle he had, I went to his workshop and we fitted that. On the way home it did seem to be much better and the front end felt much more precise so the ball joints had done the job. Over the last few weeks though, the whine still seemed to be there. I wasn't sure if it was me being hyper sensitive to it and do remember my missus once saying that it sounded like a bus and had almost come to the conclusion that it had always been there. The noise always seemed to be coming from the centre of the car. I'd changed the transfer case anyway and that hadn't made any difference so I was starting to suspect something in the gearbox. But dropping it into neutral didn't cause the noise to change and running it through the gears with the transfer box in neutral and it wasn't there.
Yesterday I decided to convince myself once and for all so crawled underneath and dropped the rear propshaft off. Took it for a run down the road and realised that it is most definitely the rear diff. What a difference with no drive through it, near silent just as I remember it! No noticale slop in it at all but something definitely isn't right inside. However, I did come very close to a major disaster. I got home, went to refit the propshaft and found the parking brake drum had almost fallen off. The countersunk screw that holds it in was on the last turn of it's thread and another half mile or so and the drum would have fallen off and shot out from under the car doing who knows what damage on it's way out to freedom. So if you are going to try running with no rear propshaft, make sure you put at least one of the nuts onto a stud to hold it in place.
A visit to Avenger 4x4 to pick up a replacement rear diff would seem to be my first call tomorrow. Unlike the front, the rear is a piece of piss to change......
