They are TE Connectivity connectors, RS part number 531-4540 (https://uk.rs-online.com/web/p/wire-housings-plugs/5314540/) or 531-4607 for the 4 way.  I can't remember which one fits into the plug that is there (one is for the plug, the other for the socket and the pics on the RS site should tell you).  So for the other one (8 way but with only 7 ways used) you would need 362-9064 or 362-9187.  You'll also need the connectors to go into the housings but they only come in packs of 50, part numbers 712-1911 or 712-1921.
The one on the RH side gives you the standard 7 wires for a 7 way trailer socket, whereas the 4 way one on the LH side gives the additional ones used if you have dual sockets or the modern 12 way socket.  That one has a permanent live, ignition switched live, reversing light feed and ground.
All running perfectly on LPG
