After doing the heater matrix and o-rings on our Vogue SE in January 2020 and having to bypass the matrix again early in 2021, I’ve got the dashboard out doing the whole job again.
This time I’ve opted for an Audi heater matrix and have removed the metal pipes through the bulkhead and replaced them with silicon pipes connected directly to the T’s in the engine bay where the LPG comes off the heater hoses.
After finishing I decided to fill it with coolant with the dashboard, airbags and HEVAC panel connected so that I could get it pressurised and check for leaks.
All was going well at this point, no leaks visible and everything seeming to be tight.
I then moved the flaps on the heater box and am a bit confused now… On the Windscreen setting I’m getting heat on both sides, however, on Face/Lap and Feet I’m only getting warm air on the drivers side. On the passengers side I get cold air.
I had to split the heater box so that I could trim it slightly to get the Audi core in and am wondering if there’s a chance I’ve got something in the wrong place.
Open to ideas on best things to check though :)
David.
