But if you'd picked the one marked LHD, you'd have the picture for RHD. As you say though, back end is the same so it isn't really important.
But, back to the plot. Been under the Ascot which is a 96 so has the earlier pipe runs but has a twin exhaust on it.
Looks pretty close but there's around 3 inches of clearance, the pipes run behind the alloy plate that has been added as a heat shield for the LPG pipework and wiring as per CoP11 (heatshield must be fitted if LPG pipework is within 100mm of the exhaust).
The exhaust system is genuine
and the mounting brackets are there on the chassis on both sides so, even with the exhaust running close to the brake pipes, LR intended it to be possible to fit a twin system to an early car.
- '98 Ex-Greater Manchester Police motorway patrol car, Range Rover P38 4.0, in white with a not very recently cleaned cloth interior
- '96 4.6HSE Ascot because you never know when you might need a spare
