davew wrote:
Guessing you already know about the alarm/RF problem plus the BeCM staying awake for over 2 minutes etc ? If not search for BeCM SID on here...
As for the 0.8-.9A drain it could be a few things (!!) but I would start with the EAS... so try pulling out its Timer Relay under the LH seat ?!
Probably the easiest way to 'bypass the drivers door switch' is just to use a screwdriver to simulate the striker ?
Needs a calm environment (eg. garage) of course due to motion detector (alarm)
I'm aware of the RF issue, we fell foul of CCTV in my car. But my almost identical (1 year younger) Vogue parked next to hers isn't showing the same symptom. I've also seen the joke "solution" with the aluminium box on the circuit board.
I thought the BeCM timeout was longer, so I've been giving it 15 minutes.
We've removed the CD changer and Satnav from the boot area. Satnav head unit TBA.
Thanks for the tip about the black timer relay. Wed pulled the under bonnet one with fuse F29 (but missed fuse F40). I'll put those back and do what you said.
I'll see if can figure out where to stick the screwdriver for the drivers door!
Thanks for the help. This forum is priceless.
PS I'm leaning towards it being something inside the car, as there's a lot of stuff powered while ignition is off, right?
2000(W) Vogue 4.6 Black/Grey
