Hi all,
I've recently aquired a cheap 1997 4.6 V8 that I've got an MOT on and seems to drive nicely. I've fixed a few issues like high idle, used MAF, new lambdas and bushes but one has me stumped.
The temperature needle on the dash doesn't move, if I short the connector out at the sender the red overtemperature light comes on but the needle is still on cold. Does anyone know if the light and needle movement are independent or if it should move to H when the light is on am I looking at getting some new clocks? I've connected the Nanocom and the engine ECU is seeing 90 degrees when the attached photo was taken.
Thanks, Matt.
