Hi, I thought that I had solved a problem with the drivers' side door latch blowing up and locking me out of the car. I did the LR emergency manoeuvre and bashed the latch with a steel rod, thereby allowing into the vehicle. I then got a new door latch from my usual LR dealer - but, as has been pointed out, the "f***-up" of the electrical connector plugs came into play.
The door latch that arrived has - yes, you guessed it - two connector plugs. But my latch has only one. F, f, f*** !!!!
So, I am wondering whether I can take the original plug off my broken lock and then take the two plugs off the new lock and reconnect them into the old single plug, to reconnect to the wiring loom.
The first picture is the new, two plug arrangement; the second picture is the original plug off the banjoed door latch; and the third picture is the plug connector on the end of the door wiring loom.
The correct door latch is FQJ103260 but this is NLA and LR tell me that they have no prospects of new stock arriving. So this leaves the second hand market with the prospect of the door lock failing again, whenever it feels like it. The latch that I currently have is FQJ103220 but it is for the previous model of P38. The part number FQJ103260 seems to have been fitted to very late P38's and when I asked LR they said that that part number shouldn't have fitted to my vehicle, based on the chassis number. BUT - it is !!
If it is possible to rewire the plugs then it will avoid having to [a] buy second hand; and [b] rescue the cost of buying the two plug latch.
Any suggestions would be most welcome. A last comment - I have seen a new passenger side door latch for a LHD P38 with the correct plug, and all the mechanical lock connections in the correct position. But would this door latch work in the drivers' side door on a RHD vehicle ?
Pierre3.
