Both front hubs recently changed due to bearing wear.
ABS sensors didn't make it out alive.
However, Front Right threw a wobbly a few miles later.
Replaced under warranty at no charge.
However, the problem has come back again, again not present for garage test drive.
Nanocom says:
12-05 FRONT RIGHT SENSOR SHORT TO ANOTHER 012 TIMES
We have glove box out and WABCO available for testing of the unit, or multimeter and oscilloscope readings from the plug pins. Though the latter would presumably require some messing about to supply power?
All pins in the unit are shiny and free of green or blue deposits.
