Weird?  Looking at the plugs you've got and the diagram, all the wires seem to be there just not quite how I would expect them to be.  Brown wires are power, not ground, ground wires are black on modern wiring.  The 3 pin plug you've got would appear to be what is shown as C0941 on the diagram, a red/green from fuse 40, the white/grey with yellow band appears to be the iBus connection but why the brown doesn't continue to where it should I've no idea.  On the larger plug, you've got the colour codes that match the diagram but where the extra wires come from or what they do, appears to me to be a bit of a mystery.  The diagram shows three wires, a white/blue, a white/red and a white/brown at the plug marked C1353 but you've got two of each.  Then you've also got the red/green and the white/grey/yellow that should be on a separate plug as well as a pair of spurious brown wires.  Unfortunately, unlike the diagrams for the P38, the ones for the L322 don't show a face view of every connector, just some of them so I can't see what C0941 and C1353 should look like.  What year is your car as the diagram I'm using is for models up to 2005 so if it is later it may well be different.
I'm wondering if there should be another cable that attaches to what you have and goes between that larger plug and the CD changer unit.  What connections are on the changer, the same as you have plugs for?
This is one reason why, if I ever do decide to risk an L322, I'll avoid a Vogue like the plague.  I'd rather have a standard sized hole I can fit my own DAB radio into and use a separate satnav that doesn't need a CD that costs more than the average Tom Tom when it gets out of date.  But I have been accused of being a Philistine..............
All running perfectly on LPG
