A couple of days ago I took the car out for a short run after doing a calibration check on the LPG system. All correct I pulled into a layby to turn round and as I started to pull away, the car hesitated a bit. Got home, let it cool down and then checked the auto gearbox fluid level. At the minimum mark on the dipstick so topped it up but didn't consider this would cause a problem. While puzzling over what could be the problem, I had the engine running with the bonnet open and a strange noise started. Initially I thought it sounded like it could be something driven by the serpentine belt so took that off and started the engine, still there. Then realised it was coming from under the car......
This is what it sounds like video with the noise. It seems that the gearbox oil pump is dying. Oddly the car drives normally, except for the intermittent hesitation when pulling away from a standstill. Once moving, it changes normally but the noise can be heard from outside the car. Looks like I'll be adding to the 'what have you done today' thread with details of a gearbox change in the next few days......
I certainly don’t know what a failing pump would sound like. My first step would be to remove the transmission pan and filter to see what I could see.
While recording the noise I was changing from P through R, N and into D. Each time I moved the lever, the noise changed sounding like it depended on how much load was being put on the pump.
My first step was to send that video to a specialist for his opinion. Second step was to order a replacement gearbox and torque converter.....
Presumably Ashcroft? I suppose you’re probably due anyway.
