I have 2 Range Rover's, I know, I must be insane.  My P38 is the one I am in need of help with though please.
I have a few issues which I need to sort and pretty fast, and a cosmetic question that I know I will get ridiculed for.
Firstly before I go any further, Range Dog is a rough looking (at the moment) modified 1996 4.6 HSE with LPG.
These questions aren't in prioritised order, and I am limited with my disabilities which I have had from birth.
Problem 1.
My front passenger door card dropped stopping the door from shutting, it was raining, I was desperate to get home after picking my car up and driving for the 1st time in 3 months, so in a paddy (I don't have many, honest... lol), I yanked the door card off which bent the thing with the door lock pin on it that shows through the door card, slammed the door shut, and now it won't open from either the inside or outside. MOT has now run out, and it won't pass one for obvious reasons.
Problem 2.
Coolant loss from a location I can't quite see, (Above the oil filter housing), and the cooling system does not match that on the Rave manual for the Gems engine set up, although I have a Gems engine, and doesn't quite match the Thor engine set up but is closer to the Thor set up than anything.
Problem 3.
Using oil, I hope to have solved this, but not able to tell yet as I cannot drive the car, I found the breather was totally blocked and very thin and stretchy, I have bought new breathers already and the smoke that was coming out has more than halved, so hoping I just need to give it a good blast.
Problem 4.
Intermittent Electric Windows.
Problem 5.
ABS and Traction lights on despite new ABS sensors and replacement hubs on the rear.
The cosmetic thing.
Range Dog has a far from standard look anyway, and I love having it looking different, if I had bought it in factory condition, I would have kept it that way, but keeping it unique, I have been given a spare P38 Grill and have bought a very cheap RR Sport supercharged grill and like the look of the 2 combined, however I cannot see any guidelines on how to do it, does anyone on here have any photo's of one being built please?
Thank you for taking your time to read my post.
