Well i figured i should put together a short summary of the trip.
We drove 1200miles over the weekend, from Glenrothes to Fareham, visiting goodwood for 3 days then back home again. It made it, without needing a flatbed truck, which i was quite pleased about.
No cruise control was annoying, as the ECU didnt turn up in time. The AC worked surprisingly, despite the leak, and was a godsend on the return leg where it was really quite warm!
The trip did throw up a few issues, with the BECM going in a huff in the Harry Potter tour car park and immobilising the car for a period. That magically fixed itself, but then it sprang a fuel leak on the way to the hotel.
https://www.dropbox.com/s/cqamhk5ji5hhd8p/2017-07-02%2023.09.19.jpg?dl=0
https://www.dropbox.com/s/a786gl72ax9jk2m/2017-07-04%2010.52.11.jpg?dl=0
That hose on the return line is 10mm LPG hose that some arsehole has used to join the tank to the return line. Its all perished and has split around where the jubilee had crushed it down to 8mm. 30minute walk to a nearby pirtek (via euro car parts, who didnt have any fuel hose...) for a length of hose and a repair in the hotel carpark on monday morning and we were off again, albeit a couple of hours late!
A few more minor issues came to light as well, some mentioned above. I replaced the rear track rod before we went as one of the boots was split and the balljoint was rusted up. While the front one felt fine, we discovered once we hit some minor back roads that it was a nightmare to keep it in a streight line, with the steering pulling wildly around the place on camber changes, and discovered the balljoint on the front bar now also had play. At least one of the axle end balljoints is also creaking when turning it, so i guess its dry as well? Those look like a pig to change! I'll replace the front panhard rod bushes as well.
The brake pipes on the rear axle are a total bodgefest and were clattering off the axle tube over slow bumps in traffic as they're completely unsupported over their length. Temporarily fixed that with ducktape but the pipes need properly recreated and the appropriate mounting tabs need fitted. It appears to be a later style axle case, that someones bodged the early style pipes onto, and ofcourse that means theres no locating tabs etc.
The car also managed to use about 4L of oil over the course of 1200miles. When we arrived at the hotel (500miles) there was barely a drop on the dipstick, and it took 2L to fill it back up again. I kept a closer eye on it after that and topped it up regularly.
The exhaust, despite sounding epic around town and while being a bit chavvy revving it in tunnels, has an awful drone around 2250rpm. Its not usually an issue, as motorway driving is up closer to 2800rpm where its quite civilised, but once you get in some traffic and are doing 50-60ish it was really quite annoying. I often found myself forcing it into third gear to keep the revs up. So i'll need to get a small silencer added to replace the middle box (though realistically i knew that anyway)
The transmission was otherwise fine, despite me fearing the worst due to its oil leak and horrible noise it was making before we left, and after repositioning the sump gasket appeared to retain its oil without issue.
Theres probably more stuff, but i cant think of it just now!
                            1994 Range Rover 4.6 HSE - Rough, but has an MOT!
2000 Audi A4 1.8T Quattro - Long term weekend car, 'slightly' modified...
2022 Skoda Enyaq - EV daily driver.
