So...
Today I went off to buy/collect a whole load of bits from the guy I bought my project P38's off - got a couple of dash fascias, switchpacks, HEVAC controllers etc all to be pulled apart and overhauled... I also ended up buying most of a GEMS engine... which was apparently the original engine from my 'R' Reg. The problem... it's got a couple of liners which have damage around the top of them... Oh, and a piston missing...
I've attached a pic, but what's the thought on whether this thing would be fixable with (top hat liners obviously). I got the block as it is, a pair of heads, front cover, rocker covers, lower inlet manifold, and another set of 8 pistons/rods for £250 - so figured it was worth the punt, as if it is salvageable with top hats, then it will be nice to put the original engine back in it, and will mean I can build one up to just swap over.
He said that it wasn't using any water, but just had a knock on it. There's another cylinder up the front which is about the same, but I was more worried about this one as it's next to the water jacket.
Thoughts?
Marty
