Hi all.
Went to a local car show the the RR today and as we were waiting to get in the EAS warning came up on the dash along with all the hight lights. Compressor was working and the car still self adjusted the ride height. The car didn't drop to the bump stops and stayed at the normal hight. I restarted the car after a couple of hours and all is back to normal no warning lights and the system operates as normal. Drove the car home a bit later again with no problems. Any ideas.
Rob.
Iffy connection in the multiway connector in the LH footwell. The Ascot did it to me and it was losing supply to the lights so the one showing what height I was at would go out momentarily. That would cause it to beep and bring up the EAS fault warning but then the connection came back, all the lights would come on as it rebooted, just as it does when you first turn on the ignition and it carried on as normal until I hit another bump. I just chopped out the connector and soldered the wires straight through.
