Up until yesterday, all was well in Range Rover land. Then the rev counter decided it was hooked up to a screaming multi - cylinder Japanese two stroke.
Not quite, but it overreads by almost 1000rpm. So on tickover it sits at 1750-1800. When driving, it pops up and down with the gearchanges but always +1000.
When I switch off, it drops to 1000, sits twitching for a few minutes, then drops to zero.
Left it overnight to see if it would just disappear, like you do, but no, same this morning.
Before I go wailing into things, any bright ideas, guys?
Isn’t there an instruments section on the nano ?, I haven’t played that far yet, surprisingly, lol
Unplug the RH multiway connector to the instrument cluster and give it a dose of contact cleaner. It's driven by the engine speed pulse train from the engine ECU so I doubt that is wrong......
Thanks, Richard.
I'll be giving that a go in the morning.
So I did. And lo, it remained the same. Interestingly, it was reading 1000 when I came to it this morning. Dropped to zero when unplugged then back to usual when plugged back in.
Tried the BECM end of things, plug 16, if I recall. No change.
Took column shroud off and had a peer at ignition wiring. It all looks remarkably unmolested.
Buttoned it all back up as I had to be rolling by 11, so none the wiser.
The thing is getting a feed from somewhere, even when the key is in my pocket. Mystery.
Two other things came out of today; one, it spelt the final death of the binnacle surround and two, I've lost a really annoying rattle.
You win some, you lose some!
Minimum Intervention Cure
Remove battery earth. Leave for a period (two days in this case!).
Replace battery earth.
Problem gone! :-)
Nice one, it had all the hallmarks of an iffy earth anyway so having a poke around and clean up might be a good idea.
