Stereo decided I would like to hear sounds from the front right drivers speakers only this morning. Can’t fix the issue.....
Read that this could be due to a faulty Nav unit, so I unplugged said unit, same problem.
Suggestions?
Which car is this on and does it have the DSP amp?
Have you checked connections at back of radio
P38 and yes to amp
I actually meant which P38 but if it has the DSP, Marty is the only one that may be able to explain what is happening.
Cheers Gilbertd,
I’m trying to keep it original and thereby avoiding putting a gash Sony or such head unit in to replace the stereo
If it is the DSP amp in the process of turning up it's toes, then Marty has produced a drop in replacement that uses 4 door amps from the pre-DSP model. At least that allows you to keep the original head unit so it all looks original.
