What can I say, bought a set , put one in to compare against my 100w xenon bulb, the difference is unbelievable, it’s like the xenon are candles in a jar, £47, but worth it,,
What's the beam pattern like? I know the Power UK ones OB fitted could be adjusted to get the correct pattern although they were the best part of a ton a pair. Either the ones they are selling now are different or the price has come down. I bought some eBay ones and they were bright but spread the light everywhere so I went back to the Osram Nightbreakers.
They are the ones OB bought, they finally have back in stock since they reduced the price, the beam pattern seems fine, I’m getting it on the beam setter tomorrow.
My other half saw them on in daylight, she said there’s no way I’m driving in front once there set tomorrow, I’ll get some pics tomorrow night of beam pattern.
Definitely interested in beam pattern pics.... If you get them set nicely, then I might treat mine to a set!
No problem, I’m happy as they are, just having the beams checked as don’t want everyone flashing me.. will get some pics tonight.
Update, went to adjust one of the bulbs, inserted Allen key to find it just spun, so looks like someone had stuffed it up and returned them, I will get it out today and hopefully adjusted to take pics/ video tonight
Not had much of a chance to play with the car, but took some pics of before it’s going to headlight alignment checker, I’ve looked at many driving along and the beam looks pretty much the same, including the beam to the side!(https://i.imgur.com/nuyRbfe.jpg)
https://i.imgur.com/13i8usi.jpg
You can see the difference straight away,, each garage door is 10ft,,
Better photo would be against a solid wall showing the pattern from about 5 feet away 👍
