OK guys-- no one warned me about swollen lug nights on the Hurrican wheels-- let alone that you need to pound on a socket to get them off-- and ----the wheels will be rusted to the hubs.
Went for my first ride today hoping I will not have much of a coolant drop (I did and just hoping it is a final burp rather than going somewhere where it should not) and I hit 51 mph and what I think is the right front tire starts to imitate a paint shaker. It eases off at about 65 mph so I am hoping it is an out of balance tire. I figure a flat spot will show up at every speed.
So go to take the wheel off and find the magic swollen lug nuts. Great design for a truck designed to go off road and through streams. I had to pound on an SAE socket which was a hair larger than my 27 mm socket. My air hammer almost could not release them-- kept tightening and loosening and finally all came off. I went ahead and removed all of them on the four wheels. I had to cut off the stainless cover on two of them.
Then came BiG LEAD HAMMER TIME. I tried the push-pull method to maneuver the rims off and it laughed at me. Got on my back and hit with my feet-- zero movement. Pulled out the 20-pound lead hammer and after 10 minutes pounding the tire sidewalls from side to side and top to bottom, I got them all off.
Check the right front on my balance machine and it was only off a small amount. Looked like there was a small flat spot but normally with large cross section tires you do not feel them. So could this be another P38 front end gremlin I need to learn about?
If not the tire or rim- can I assume that when something is worn in the front end you will get a shake at a specific speed with these trucks? Everything seems pretty tight-no movement I can feel. Probably will need a small crowbar to work the ball joints to detect movement- but with my arms doing the lifting and pushing I feel nothing.
I wonder what the next fight I am going to have with this truck as we become acquainted.
