I have had this issue for a while and I am finally trying to solve it. Symptoms are as follows.
Driving in town and I will pull up to a stop light and notice the front is low. I then put on the park brake and take my foot of the brake. When I do this the truck will level out, sometimes in 10 seconds but sometimes longer. If I drive all the way to work without performing this procedure when I park the truck it will level once I put it in park. Sometimes the rear will move around while this leveling is occurring almost like a seasickness motion (like the bags are inflating in a circular pattern).
Before we start I will try to answer as many of the possible questions that I can.
  1. Driver module replaced - same symptoms
  2. No leaks detected on bags or lines.
  3. Valve block rebuild 3 times in last 3 years.
  4. Replaced all o-rings on bags and dryer.
  5. Swapped height sensors and replaced one where tab snapped off due to rust.
  6. Calibrated EAS using dowel blocks.
  7. Truck does not drop at night. Sometimes raises while parked.
  8. Truck does not move if relay is removed.
Any help with this would be great as drive-ability is an issue.
