Hey guys,
Does anyone know if the seat cushion is the same on electric and manual models and also if left and right are interchangeable.
My cushion feels like it has disintegrated and i bottom out if going over some bumps etc :(
Thanks guys
Yup, same on all versions and interchangeable left to right. There's a plastic strip where the base joins the backrest that you need to prise off and 4 Torx headed bolts.
Excellent. I'd be better off getting a passenger side one as they tend to be used less :)
Thanks Gilbertd
After being sat in by a copper every day for 8 years and the best part of 200k miles, the outside edge of my drivers seat was looking pretty rough. I bought a passenger seat, stripped it down and replaced my drivers seat base with the virtually unused one from the passenger seat. The plastic strip takes some levering off but once you've got it started, it comes off easily enough. The seat needs to be out (obviously) and set at fully reclined so it is flat.
Thank you :)
