We've just lost another resource.
http://lrparts.ru/ have removed basically everything previous to about 2007 and no English links either.
I've not used them since long time, I find this link much more useful - until I finally manage to install the cat, that is.
http://lrcat.com/#40
Your best bet if thats Microcat you mean, is to install vmware player and then install windows XP inside that vm. Unless you have access to a computer already running XP that is. Anything much newer (definitely if its 64bit) doesn't want to play with it.
That's the old one, you need to use http://new.lrcat.com/
Agree with Brian, Microcat won't run on anything later than XP, 32 bit, won't run on Win 7 or any 64 bit version. I just run it on an old laptop running XP.
Yeah, I know about the lrcat one.
It's not very user friendly with the parts list.
I've got microcat on an old 32bit so laptop along with easunlock and other diagnostics:)
I uploaded a copy of Microcat onto this forum a while ago. See under "Handy Downloads".
As Brian said, it needs to run under 32 bit XP and the best way is using VMWare under windows 10.
I am actually using Windows 10 64 bit. It is faster using a virtual machine than XP on an old pc.
