In the process of replacing the one remaining (rusted) steel brake pipe on the Ascot that was put down as an advisory on the MoT. It's one of the ones that runs along the back axle but the bracket holding the ends of the two hoses that run from the body to the axle is pretty bent and mangled. This means that the pipes that come from it are tight against the diff housing. Started straightening the bracket and there doesn't seem to be a lot of slack in the hoses. Should the hoses go above or below the panhard rod? At the moment they are below it and the protective spring thing is wearing but if I route them above it that will put them closer to the exhaust. Which is correct?
