have little issue vehicle will start but not run as soon as you touch the throttle it tries to rev and then dies . i will be looking at the throttle positioner to start with , dose anyone else have ideas on this
I'd go with TPS too. Easy enough to check with a multimeter.
I cant remember if you have nano, but if you do then I think you should be able to turn on the ignition and then take the voltage of the TPS as you press the accelerator ie even with the engine stopped.
so i have checked the TPS all is good so reset adaptive values and tried to start now it will start and run 3 4 seconds and stall out no throttle response when i checked yesterday the nano showed that an o2 sensor wasn't working now it wont run so i have no readings
Low fuel pressure? One lambda sensor not working just means one bank will run open loop fuelling but it will still run fine.
