ok i give up how do you post a bloody photo step by step please.
I believe you will need to host the photo on a third party web site, for example Photobucket (although I'm sure there are other free ones), then when you click the photo icon when writing a post it gives you a box to insert the hyperlink to the photo you uploaded to that third party website.
You can't host photos on your own computer, it must be web hosted.
TBH I struggled with this just recently, trying it for the first time.
I opened an account with imgur - free and seemingly well-regarded - and uploaded some photos there.
Then, when writing the post, and wanting to add a particular photo:
1) go to 'imgur' (or wherever)
2) click on the photo you want
3) it should give you a set of 5 or 6 links on the right hand side.
4) copy the 'direct link' one
5) come back to your post on the 'Pub'
6) click on the little photo icon in the 'edit bar' above the text box
7) paste the photo link in there...
8) I was then deleting the wording which said 'describe your photo' - or something like that, because it's usually obvious from the text.
9) do a 'preview' of the post just to check it's the right photo and that it's worked.
Hopefully that will work - but maybe others more experienced will jump in. It did take me a little trial and error.
Donald
That's spot on except for point 8. Don't delete any of the wording that appears in the link and the picture will appear, delete any of the text and all that appears is the words, Enter image description here. The other thing that catches people out is in imgur, the second box down, marked Direct Link, is the one you want but when you click the Copy button next to it, it doesn't automatically copy the link, it just highlights it so you still have to right click on the highlighted bit and click Copy.
If it doesn't, it won't work.
thank you for info very helpful.
For anyone using Onedrive to share photos, the right option to use is to open the photo in onedrive, then click the embed option. This will bring up another box, with a code like this
https://am3pap004files.storage.live.com/y4m7QNGOMUaUg8MOVu42hcjf4EkLuBjWnyPE0Fs5BDQyXQQQLw5F6hwy7JS4Pkv2wFEdOTK-JYu-ChMZkv78Dw35WacciSdbBk6r-RXHIEBzIWKoOnotw0Y9yQtH4_OirbBlBqgXkm_2ot_Jl9eI6qIyIBqNqqI-Gzmp0jACT63LKk?width=3024&height=4032&cropmode=none
Paste that into the box in point 7 and you should have your photo linked sucessfully. Sensible to put said photo into the public folder first on your onedrive.
For those that use Imgur, I would also add that you can chose the picture size as well (small, square, large thumbnail, etc.) at the bottom of the list on the righthand side. As mentioned also use the direct link. A large square picture is really big. Large thumbnail is OK for this forum.
You can also choose size on onedrive - default is original size. Probabbly worth also saying, that if you give it a go and find you've mucked it up somehow, you can have another go using the edit function (Green pencil button at the bottom of your post) to correct the error and try again. Or use the preview button first to check it. Easiest to delete your link from the post and start that bit again though rather than trying to correct the error with onedrive links.
Has anyone sussed it on a iPad yet, think once I managed, but don’t know how, lol
be good to upload straight off phone as most my pics on there
Dedicated picture hosting was something Gordon has been meaning to look into for a while so you can upload directly to the site. Maybe a lockdown Christmas will give him time to do it (although as he recently became a father, maybe not....).
ah ok then thanks for letting us know
congratulations Gordon on your new addition to the clan
