Hello, P38 Gems gearbox flexi plate access panel? I have three bolts missing. Does anybody no the part numbers please.
Small ones, FS106257L, M6 x 25 flange head, larger ones with the conical bit behind the head, 594134. Although I don't think I've ever come across a car that has had all of the bolts in.
Thankyou, odd that isn't it. Cheers
The small 8mm headed ones do tend to seize in for some reason and the heads appear to be quite soft and round off easily. I've resorted to giving them a tap with a cold chisel on the edge of the flange to get them moving at times.
Thankyou for that, it all helps
