Not sure if anyone's had this,but: for the last couple of days when cornering right i have noticed a bit of a creak coming from under the car, seems.to be the rear. It sounds as if it is on rusty springs, which it's not...
So this is if i'm either going round a RH bend at 30+, or also as i'm exiting a RAB ie also steering right). I dont think this is a steering thing... Front suspension is pretty much all replaced in the last year, along with rear shocks. Could be an anti roll bar, or bush ( i'm guessing rear) i also thought exhaust mountings. Anyway, i'll go under and have a look, just curious if it rang a bell with someone...
Problem solved - two hanging rubbers on one side of the exhaust had surrendered at the same time
I would put money on one having given up long ago and the extra weight caused the other to let go recently.
No doubt that is the better explanation, yes, and now that i think on it, a few months back the exhaust started to bump if i went over a speed ramp - so that was probably no 1 gone
And we like a nice easy fix!
