I'm trying to keep as original as possible and the car arrived with a replacement left front ride height sensor which has the kit of tinfoil heatshield where the original set up had a plasticky/bakelite sort of cup over the sensor.
As the replacement sensor won't fit the old bakelite cup does anyone know of a source for the original ANR2494 or have one lurking at the back of the shed?
There is one in the U.S. used but otherwise they are showing as NLA.
Very happy to swap with the current sensor which reads OK on the meter.
I’ve got two that are on a car I’ve been breaking for years. I’ve no idea if they’re any good though. If you get stuck, let me know and I’ll try and get them off and measure the resistance across the movement to see if they’re any good.
Thank you David, that would be great. No hurry. It is only the left hand one I need as it has the top entry wiring. Why it should be the only one made that way is a mystery.
